Our hydrochloric acid pickle line for hot rolled steel sheet contains copper levels in the area of 30 ppm. Under certain (unknown) conditions copper is plated onto the steel sheet. What parameters can I change to prevent this?
We are going to look for the source of copper, but assuming you can't bring down the copper levels what else can you do?
Is it possible to use a dummy cathode with a DC source so that copper will plate there instead of onto the sheet?
Can any chemicals be added to react with the copper ions without affecting the pickle process?
What if a less noble metal such as zinc is introduced in the bath? Will copper preferentially plate on zinc instead of steel?
Feel free to give me a lecture on the basics of plating cause I'm not an expert
Thanks guys
