Can anyone suggest possibilities of why we are reading 120vAC across CB A2-3 TIE on the attached one-line diagram? All breakers are closed unless indicated w/ "open". Readings were taken at VM1 and VM2 as shown on one-line. VM1 readings were 120vAC across the line side and load side of CB A2-3 TIE. A-A, B-B, C-C, and all combinations. VM2 readings were 0vAC between line side of CB A2-3 TIE and ground, and Neutral. Thought it might be ghost or phantom voltage, so we tried a solenoid actuated "wiggy" style voltage tester with same results. [URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1714505443/tips/S24043014471-1_y0cfgo.pdf[/url]
