Unhandled operating system exception : c0000005 error while opening NX 7.5 4
MustafaAsan
Automotive
FR
I can't open my NX 7.5 because of this fatal error. Does anyone have a solution about this problem? Thank you.
(My operating system is Windows 8)
Mustafa.
Has this worked in the past or are you just now installing NX for the first time.
If it's the first time, then check with either Siemens or whomever you've purchased NX from. If this is a new problem which has just surfaced, then I would take it up with GTAC.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Bu sitede lisanssız kullananları pek sevmezler hocam :)
Kaan01, lisanslı hocam lisanslı :) Sıkıntı yok :)
It was working before. I suddenly got this error. I also can use GTAC but I wondered if somebody here faced this problem before. :)
@JohnRBaker
By the way, thank you for your advices & help. It's a new problem for me. I would be happy if you can ask this to GTAC.
You need to contact GTAC yourself as they will need to see your syslogs and perhaps even the files involved.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
My client is having the same problem. His NX7.5 cannot be open but NX8.5 and NX9 can. I believe this is not software related issue, nor a license related issue. One thing we have tried out is we remove the user profile, and add in a new user profile, and things seems to work as normal. But after sometime, the NX7.5 again cannot be opened.
The syslog file indicates something like
*** COLLAPSE:: in line 2727 of D:\workdir\reference\NX755_4\src\syss\error\ind\error.cxx at Tue Jul 08 09:40:07 2014 Malay Peninsula Standard Time
+++ Unhandled operating system exception: c0000005
I believe this is related to permission of the user. If you tried to start NX7.5 with administrative right, probably NX7.5 can open without problem. Currently we are asking GTAC about it as well.
Kind regards,
Tuw
Hello Tuw,
Thank you for the information. I tried to open as administrator also but nothing changed. I have exactly the same problem (no problem with other versions, just 7.5). Could you please give me the IR number? I want to follow-up this IR.
Hi MustafaAsan,
It is IR 2240418..
There was a problem with NX7.5 and a corrupt registry entry where NX7.5 wouldn't start.
I can't remember the error message but you can try the following:
Using regedit (the registry editor),go to the key HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\7.5\Layout\Railing then delete FrameMarker (see image).
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.1
@PhoeNX
Right point! My NX 7.5 opened after this regedit configuration. Thanks alot for this info!
Greetings.
Write it down. From my experience, it only happens with NX7.5 and it doesn't happen all the time, but it does happen randomly.
Not sure if patching to later releases helps but there is Maintenance Release NX7.5.5 available for NX7.5.
Anthony Galante
Hi PhoeNX,
Thanks for the suggestion. It works for my client too :)
Tuw
It happens enough here that I have created a batch file. I'm thinking about adding it to my start NX batch file but not sure what kinds of other problems that would create.
Code:
echo off
REG QUERY "HKCU\Software\Unigraphics solutions\NX\7.5" /f "General" | find "General" >nul
if %errorlevel% equ 0 (
REG COPY "HKCU\Software\Unigraphics solutions\NX\7.5"  "HKCU\Software\Unigraphics solutions\NX\7.5-save" /s /f
REG DELETE "HKCU\Software\Unigraphics solutions\NX\7.5" /f
Echo Deleted 7.5 keys
) ELSE (
Echo 7.5 keys not found
@moudy1, the way you have it set, it will wipe everything stored in registry for the user. So things like file history, window locations will be removed.
Change it so it only gets rid of the 'Frame Marker' key and then everything else will be retained.
Anthony Galante
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
Hi all,
The problem happens again today on my client. So as PhoeNX had mentioned, it does happened randomly. Please noted that my client is using the latest patch NX7.5.5.4mp12 64bit
moudy1, is there a way to create the .bat file you mentioned that only delete that particular Frame Marker registry? I think we will need it as it had happened enough already.
Code:
echo off
REG DELETE "HKEY_CURRENT_USER\Software\UNIGRAPHICS SOLUTIONS\NX\7.5\Layout\Railing" /v "Frame Marker" /f
) ELSE (
Anthony Galante
Hi PhoeNX,
Thanks a lot for your help!
Thanks should go to moudy1. Nice little script he wrote.
Anthony Galante
