Uni-Flange Concerns
TJH2161
12
I am currently working on a project where we are replacing some old piping and valves inside of one of our booster stations. The lengths of the spool pieces that need to be installed will need to be field-verified prior to installing. Because of this I called for FL x PE pipe so the Contractor could field cut the spool pieces to the exact length he needs and use uni-flanges to connect pipes to fittings. The contractor reviewed the plans and asked if they could use Fl x Fl pipe and just install filler flanges to fill the gap between the ends of the pipe and fittings because he does not feel comfortable using uni-flanges. I don't have a problem with this, but I was curious if anyone has had issues with uni-flanges in the past that would make them hesitant to use them in this application. Highest pressures at the booster station are about 90 psi. Appreciate any feedback.
Uniflanges are ideal for this sort of application. Generally though you should only use one uniflange per spool piece unless each flange you are bolting to is well supporrted against any type of movement. Uniflanges only have limited capacity to restrain the system against movement especially longditudinally.
Ashtree
"Any water can be made potable if you filter it through enough money"
Agree, no problems, BUT within mechanical and strength limits forces allowable. Correct clamping/support of the pipeline is essential. Mechanical forces by temperature and mechanical variations checked. Prefabricated dismantling pieces, lockable or not lockable could be an alternative.
IMO, depending on the location in the "booster station", it may be an issue for the uni-flanged spool if it's near the pump suction or discharge connection without proper supports.
