uniaxial strain limit - Table 5.7 ASME.BPVC.VIII.2 Chapter 5 1
tigny
110
hi,
regarding 5.3.3 Protection against local failure, Elastic-plastic analysis - Local Strain Limit,
there are reference parameters εLu, m2 and αsl to be selected in Table 5.7 depending on materials.
Table 5.7 lists Ferritic steel; Stainless steel and Nickel based Alloys; Duplex stainless steel; Precipitation hardenable nickel base alloys and other non ferrous materials.
[ul]
[li]What if the component is made of carbon steel?[/li]
[li]What values of εLu, m2 (formulaes) and αsl should be used for carbon steel?[/li]
[/ul]
best regards
Carbon steel is a ferritic steel.
Dear TGS4
Thank you for your answer, I'm sorry I didn't react before.
I was having a confusion between Carbon steels (therefore Ferritic Steels) such as in Division 1 UCS,
and Ferritic Steels [highlight #FCE94F]With Properties Enhanced by Heat Treatment[/highlight] such as in Division 1 UHT. The other few references in Division 2 allow to make the same disctinction.
Now this makes sense, thank you again.
