curtis2004
- Jan 8, 2010
- 301
Hello colleagues,
I am reviewing a design of Light Oil system with a Light Oil storage tank. The system is used to store and distribute diesel fuel to emergency generators and auxiliary heating boilers.
My storage tank is about 80,000 liters with horizontal construction and have 6" loading nozzle on top (12 o'clock) position. I have three 3" unloading quick connect ports with isolation valves connected to a single 6" header (with check valve) which then goes up and connected to top nozzle of horizontal tank.
I have one issue: How do I empty my 6" loading line and unloading hose before decoupling it? I have heard that you need blow this line with low pressure air in order to push diesel into storage tank and empty hose and loading line. However, I have concerns if this safe procedure. Does standard tanker trucks have this feature (blowing air into their loading hose) or do I need to design this low pressure air system?
Does anyone have previous experience with this type of problems? Did we had any discussion before here? I do not think this is unique situation.
Thanks in advance for your time,
Curtis
Curtis
