Is USB completely disabled or only disabled for memory sticks? Have you tried a portable floppy drive (costs about £30)? If the work will fit on a floppy, just do it from floppy.
Is the disabled USB a fault or deliberate security policy? Any method of bypassing company security policy will get you fired in many companies.
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting Steam Engine enthusiasts Steam Engine Prints
Try accessing it through DOS or typing the drive letter (with : etc) into the address bar.
The last place I was at, the must have just had the "interface" (explorer) disabled and you could access as per normal using the above (the later was a bit more "usual" of the two methods).
Lyle
