EngJW
- Feb 25, 2003
- 682
- 0
- 0
I have a tube with several holes drilled in it. Now the factory wants to make it out of sheet metal and roll it instead of buying tube. I tried to make a pattern by going back to the first sketch and keeping just the od. I put a small gap in it and then converted it to a base flange. Everything looks ok but the part cannot be flattened. Apparently SW wants flat surface for reference and does not recognize the round surface.
Is this even possible to do? I could just make a sketch and calculate the flattened dimensions if not.
