Unsteady state heat-transfer 1
Timewrap
Chemical
Hi All,
Here is a little problem on which I need your help.
This is a batch process.
A tank intially start with a temperature of -90 deg C and had to be heated up to -80 deg C in two hours. I'm considering a heat transfer fluid circulating through the vessel jacket at about 35 deg C, the return H-T fluid gets cooled up to 30 deg C and heated in a heater to compensate for the heat loss.
I can calculate the amount of the Heat transfer fluid required based on the heat load and physical properties.
I want to calculate the exact time required to be able to heat up the tank contents from -90 deg C to -80 deg C. Since it is a batch process, the LMTD gets lower and lower as the tank gets heated.
Assume there is a mixer in the tank to provide turbulance.
Your comments are appreciated.
Thanks in advance,
Timewrap.
Open up your Perry's dude. This diff. eq. has an exact solution and it's in there. In my 6th Ed. "Batch Operations: Heating and Cooling of Vessels" starts on page 10-38. If you don't have Perry's, it's also in Kern's "Process Heat Transfer".
Good luck,
Latexman
