Unsupported Length of Beam when Using Tension Rod 1
Lily_Linton
21
Hello fellow engineers,
I'm just curious if we can reduce the lateral length of a beam if we are using tension rod as collector rather than a horizontal brace?
You see, I've been using horizontal brace like angles, HSS and WTs to limit the unsupported length but never tension rod. Most of the time, I used the tension rod with turnbuckles when use as a collector but connected to the post and not to the middle or part of the beam. Maybe because all the structures I did was in site D of ASCE and since tension rod are not used for bracing on those areas, I also never used tension rods for horizontal braces.
I hope you can shed some light on these.
If you have matching tension rods on each side of the beam to accommodate buckling in either direction, and each tension rod is connected back to something meaningful,then I don't see an issue with it.
So it will be unlike horizontal bracing that you can put on just one bay.
Correct, it would need to be on either side and terminate somewhere down the line. Beams can buckle in either direction, so you must have a method of resisting said buckling in each direction. It doesn't necessarily mean you need tension bracing each way, but you need something each way.
