DayRooster
I have asked this question before without others capable of explaining much. So I’m going to crowd source because I keep seeing this detail on other engineers designs.
Disclaimer: this is a lateral stability question not a vertical gravity load question.
For an untopped diaphragm (see attachment), how are the local chord forces (from the lateral diaphragm) handled around a large opening? The reference load is the uniform load draw in red (-X direction). And the local force in question is in blue circled area. If I am not mistaken there would be tensile force pulling the planks apart at this location along the y-axis across the face of the opening. Also the hollowcore planks are grouted together. I understand the grout has shear capacity (forces parallel to the joints) even when cracked. But under this cracked condition the grout would have zero tensile capacity (forces pulling the planks apart perpendicular to the joints). Anyone done this before and have an detailed explanation for it?
Also I am searching for an explanation beyond “that’s how it’s always been done”. I have heard that enough times without any to support the answer.
