Update
vitulin
Automotive
Nov 1, 2007
79
I wanted to ask, if its possible, when you have the delayed interpart ticked and then you want to update the part, that you are working on, if you can select the parts, that you only want to update. For example, you have skeleton and top and bottom core. You will change the skeleton, but you only want to update the bottom core not the top to save the time. Is it possible somehow_?
Vit
using nx 4,04
Vit,
I think I know what you mean and I think the answer may be not really. However if it is just the one linked body in an assembly then edit the parameters of the linked body and just hit OK in that dialog at it will rebuild just the one side at a time. You do this by making the bottom your work part before commencing to edit parameters.
Or you could just temporarily close the other half of the tool before running update session. Why there isn't an update part eludes me somewhat, which is to say that I'd be more than happy to be proven wrong.
Cheers
Hudson
In the assembly navigator you can right click on the Top core and hit close. I think that the closed part will not update.
If you have mold wizard, go to the view manager and freeze the top core.
I like the closing idea. Simple and generally not very time consuming
Believe it if you need it or leave it if you dare. - [small]Robert Hunter[/small]
Guys,
Depending on your situation if you know what you're doing the edit parameters method may be quicker. It was worth mentioning on that basis because I use it frequently.
The closing method is good too but again depending on your situation it may not be appropriate both in terms of the affected data and sometimes just because it may be slower.
Cheers
Hudson
