RUGmechanic
I have two HP 30 " monitors for use with NX (1953 at the moment).
I would like to upgrade since the oldest one is from 2007 and, even if both are HP, I can't get the dispay settings the same (contrast, colortemp, the like).
Now I have the option of replacing both monitors at the same time with 2 identical monitors or get one curved monitor (49").
I searched the forum and found But, this topic is from 2018.
Does one of you users work with a curved monitor and if, would you recommend it over a dual monitor setup ?
Thanks in advance.
Older budweiser
NX1926, hp z820
Thanks in advance.
Older budweiser
NX1926, hp z820
