Surface from 2 closed curves 1
Lupen
14
Hello to all.
For an injection mould I am reverse engineering a cylinder in a tool. After scanning the end injected plastic part we make correction in tool to make it as cylindrical as possible.
To do that I am using points from which I make a closed spline (using fit curve command). Now I have 2 closed splines wich I would like to make a ''cylindrical'' like type of surface.
I am wondering what would be the best way. If I use command Through Curves I get a surface that is concave on cross section (using Aligment by arc length).
I can correct that using point alignment and matching points as close as I can but this is not mathematically exact.
So I am wondering is there I we to use an alignment (or perhaps another command) so it takes closest points from each others curve?
Thanks in advance
Luka
Dear Cowski.
Like always your the best! Thanks, it is the right solution. [smile]
Have a nice day.
Why not use a 3-point circle based on the evenly spread points on one spline then extrude that circle between the datum planes to create a true cylinder?
Because that was the hole point. This 2 curves are not circles but constructed curves from points of a scan.
A critical surface that should be cylinder on a moulded part is scanned, from this scan we design a surface that is the opposite of the resulted surface. This is than applied and machined in mould. At end we get a nearly perfect cylinder on molded part.
