EngineerofSteel
- May 18, 2005
- 156
I received a review on a simple foundation project. I calculated a perimeter footing and column footings for a pre-fab steel building.
The reviewer (who is a good engineer) is requiring that I increase the metal company's uplift by 1.5. I cannot find any mention of this in the UBC/CBC.
He said it is because:
"note that the 1.5 factor is based on the height to width ratio of the building being greater than .5"
I think this is based on sect. 1621.1:
"The base overturning moment for the entire structure, or for any one of its individual primary lateral-resisting elements, shall not exceed 2/3 of the dead-load-resisting moment."
[That part obviously does not refer to uplift.]
(1621.1 cont.) "For an entire structure with a height to width ratio of .5 or less in the wind direction and a maximum height of 60 feet, the combination of the effects of uplift and overturning may be reduced by one third."
This second part refers to a potential reduction. I postulate he has mentally fabricated a new requirement by jumbling the two parts. I found another thread on eng-tips in which another person believed the same as my reviewer, but no support was found by him or any other engineer. see it here:
CAN ANYONE JUSTIFY THE REVIEWER?
Thanks, DD
Thanks, DD
