Upright FEA correct?
Fred4
Industrial
Oct 20, 2010
0
DE
i´ve a question about FEA. I designed an upright for a virtual car. I want to check if that upright is big/stiff enough, but i´m not sure if my FEM model is correct.
The bearing cup I fix in all 6 DOF on these two surfaces you can see in the picture.
The forces I applied at the holes on top and bottom with there X,Y,Z components.
This that correct or is there another better way to do that.
I know there missing things like Brake and Steer bracket but the picture are just for showing the Basic Problem.
ok, Thank you for your answer. I will do this the other way round, too.
Are they other prof. methodes to calculate an Upright?
