Hi everyone, so we recently demoed the upstairs bathroom. House built in 2000, Dutchess County NY. Bath had a fiberglass bathtub/shower which we removed. The photo attached is a view of the floor joists directly below where that bathtub shower assembly was. I now plan on installing a cast-iron clawfoot bathtub in its place: 57" L x 30" W 317lbs empty 809lbs filled. My concern is the way the floor joists have been notched for the current drain assembly has reduced the amount of load the Floor can handle I would imagine? The floor sheathing in the bathroom consists of 2 layers plywood 3/4” capped with 1/2” pressure treated ran 90 degrees over the 3/4”. Do I need to sister lumber to the existing floor joists, change/add anything or is it fine the way it is? I Thank you in Advance!
