navycaptain
Chemical
- Jan 23, 2018
- 29
Dear Engineers:
I'd like to ask a question: what is the minimum length of upstream and downstream for rotameter flow meter?
Normally,upstream is 5D of the diameter and downstream is 3D of the diameter, but I met with one possible problem: sometimes, it's hard to make perfect flange coaxiality and parallel during site installation construction, so basically, they prefer to make it 10D upstream and 5D downstream,and also inproper flange gasket installation can make a contribution to swirl.
Do you have any experience on it? is it necessary to ask design institution to design 10D upstream and 5D downstream? are there any code od standard on this?
thank you!
Youth is not a time of life, it's a state of mind.
thank you!
