TugboatEng
Marine/Ocean
I have some negative feelings on this project and am interested in other opinions. We have commissioned the construction of a tank that will hold 32% urea solution at ambient conditions. The tank is constructed from 3/8" 304 stainless. It is being constructed near carbon steel fabrication. The tank has skip welded baffles and backer bars on the tank top. The tank will be cleaned with a consumer grade oxalic acid based product.
I know this product is doomed to fail if there are chlorides present. Does it have any chance at all assuming near zero chlorides?
