Urgent help about annotation
Ashvanth
Automotive
Feb 25, 2004
25
Hi
Please can anyone help me on keying in a 3D annotation symbol in between a text that is put for a part.
say an example of Dia symbol or tolerance symbol.
note: this is in surface.
say for example im giving an annotation for a hole in the part which shud cotain an dia synbol.
bye
Is this V4 or V5, if V4 I think the keystroke is CTL +ALT +W (it may be Q or E) try it and see, If V5 you can copy and paste from the CHARACTER MAP under START+ACCESSORIES+SYSTEM TOOLS or use ALT +0176
regards
In V5, there is a INSERT SYMBOL tool that allows you to add engineering symbols (like dia) in your FT&A text.
The INSERT SYMBOL icon is to the right of the FRAME icon. Just click on the down triangle to open up the panel.
Thanks for all ur replies.
bye
Ashvanth
