Urgent Help - Heat flux received and View Factors 1
LossPEngg
Chemical
Apr 15, 2006
13
Hi everyone,
I have been given a problem at work where I have been told to evaluate the amount of heat/radiation received by a worker at the bottom of a exchanger. If the exchanger is at a certain temperature then we can evaluate the heat flux emitted by the body using stephen boltzamn law (correct me if I am wrong). From some publications I have managed to get an equation for incident received flux which is I= t x VF x SEP. kW/m2
Where t is the atmospheric transmissivity, VF is the view factor and SEP is the surface emissive power. SEP we can calculate using the boltzman law, t is transmissivty which I think certain values can be assumed but lastly I am having problems calculating the view factor. The typical view factor equation avalilible on wikipedia seems a difficult task if I am to make it an excel version as I would need to evaluate the flux at different distances and locations from the exchanger, furthermore the person could be standing between 2 different bundles emitting heat. Once we evaluate the heat from one bindle, assmuming that the person is standing between the 2, can we just add the flux received by 2 sources? Can someone please advise on the problem?
If the subject is able to receive energy from two sources, then they add.
Seems to me that the wki artical is pretty clear, particularly: You can basically take all viewable area and divide into small, differential areas, say ~1 sq. in., and crank the equation for each one of the squares. You could treat the viewable area of the person from each differential area as a flat plate or a group of flat plates. There are probably programs for doing this sort of thing, though.
TTFN
FAQ731-376
Chinese prisoner wins Nobel Peace Prize
For 2 dimensional problems , the easiest menas of developing a view factor is the "hottel's crossed string method".
Many thanks guys. I have been able to solve the problem by assuming a value which has given me reasonable answers.
I did look at all the links that everyone provided and it was all very useful
Thanks again.
