USB power voltage regulator
luket
26
Hello All - I need to power a pressure transducer with 5V and I have a computer nearby. USB provides 5V, but it is not regulated enough for the pressure transducer. Does anybody make a device that you plug into a standard USB hub, but regulates/filters the power out to a better level, say +/-.05% on the voltage? I'm not an electrical guy, so if I've committed some kind of crime in my description, please be kind. Thanks for the help.
Luke
luket,
That's 250uV of ripple, and you're going to need more than a $20 off the shelf item to get that kind of accuracy out of a USB socket, particularly when you're trying to run a regulator with the input/output voltages at the same point.
Dan - Owner
Thanks IRstuff and Dan. I honestly don't know exactly what my voltage tolerance requirements are and perhaps +/- .05% is too tight - I pulled that from the specs of a strain gauge instrumentation box we have. Dan - do you have another option for a device that would have less ripple? It doesn't have to be small - a 'bench' device would work well.
Luke
I blew off that requirement, since it seemed absurdly tight.
If you're willing to go benchtop, then you should just get a new power supply altogether. Anything that's benchtop probably can't run off of 500 mA anyway.
TTFN
FAQ731-376
You're going to have issues with tight regulation anytime your input voltage is so close to your output voltage (in this case, they're supposedly identical). I cannot suggest a specific company/item, but like IR, I would suggest a dedicated supply (i.e., non-USB based), though not for IR's reasons of current. I would want a supply that runs off of 12V (or at least something higher than 5) and work down from there.
Dan - Owner
