Hello everybody:
For a particular project, somebody makes the calculations and selects a centrifugal pump with these characteristics: diameter of the impeller = 7¼, inlet Ø = 2", outlet Ø = 1½, speed and power of the electrical motor = 3500 RPM and 15 HP.
The BEP for this Goulds pump is around 150 GPM for a head of around 200 ft. The pump is already stored in the warehouse.
At present, some conditions have changed in this project and the new water flow is 70 GPM pumped to the same head.
The calculated power for the pump to work for this new condition is 12 HP.
The questions are: can we use the existing pump? I think there is no problem with an oversized power of the motor but, how about the speed? or do we need to change to an electrical motor for 12 HP and 1750 RPM?
Thanks in advance for your advise.
