The way I understand it now is that there can be a number of reasons why “carrier water” is used:
• to actually help carry along the water i.e. to make sure the dosed chemical achieves a certain velocity range e.g. so lime powder doesn’t come out of solution and block dosing lines
• to ensure there’s sufficient mixing of the chemical and the main process stream at the dose point (this “carrier water” could be added at the dosing pump or just upstream of the dose point)
• to ensure velocities are maintained for chemicals with high freezing points as too low a velocity and the chemical might freeze
• as motive water for chlorine gas
Are there any other reasons why “carrier water” is used?
By adding carrier water, will a higher volume of the dosed chemical be required as the carrier water might dilute the strength of the chemical (in the case of the project I'm working on 22% sodium hydroxide) or is it generally accepted that carrier water does not have an effect on strength of chemicals dosed i.e. will additional volume of chemical be required to be dosed to negate the diluting effect of the carrier water?
Cheers
Cheers
