brpillai
Petroleum
- Sep 28, 2014
- 36
Dear Experts,
I am working on a lquid pipeline project (over 2100km long), which is having piping and pipeline going from UG to AG for locations such as below:
1. Pipe crossings at road crossings within the station. these include product pipes, fire water pipes and drain pipes.
2. At block valve stations pie branching for bypass to the block valve stations as shown in the attcahed sketch. Please note that this pipe is not connected to any underground servies, only a by pass in the atmosphere.
My queries are as below:
a. At road crossings, if in the vicinity there are no underground steel pipes/ structures/ earthing, do I need an isolation joint/ isolation flange.
b. What are the criteia for deciding where Iso joints are used and where iso flanges can be used?
c. For the pipeline valve stations, as per the sketch, is it necessary to have isolation joint or can it be done wioth isolation flange?
d. Is it neccessary that isolation flanges to be used for all 31.4 and 31.8 pipelines?
Your valuable advice is sought.
Thanks and regards
Thanks and regards
