Would anyone care to comment on the meaning of the term "vertical diameter" in the following passage from API 650?
"The minimum cross-sectional area of the required reinforcement shall not be less than the product of the vertical diameter of the hole cut in the shell and the nominal plate thickness . . ."
Is there a difference between the vertical diameter and horizontal diameter of a hole? Does this imply that the hole is not circular? If so, does it mean the dimension of the hole along the meridional axis irrespective of the largest dimension of the opening?
