kammieorama
Automotive
I am running a SOL101 analysis and here is an error which I am getting
GRID POINT ID DEGREE OF FREEDOM MATRIX/FACTOR DIAGONAL RATIO MATRIX DIAGONAL
30 R1 -1.83702E+09 2.69117E+09
30 R2 -6.46914E+08 7.67864E+09
21:11:06 100:02 1025.3G 101.0 5969.5 0.1 SEKRRS 143 DCMP END
^^^ USER FATAL [highlight #EF2929]MESSAGE 9137 (SEKRRS[/highlight])
^^^ RUN [highlight #EF2929]TERMINATED DUE TO EXCESSIVE PIVOT RATIOS IN MATRIX KLL[/highlight].
^^^ USER ACTION: CONSTRAIN MECHANISMS WITH SPCI OR SUPORTI ENTRIES OR SPECIFY PARAM,BAILOUT,-1 TO
^^^ CONTINUE THE RUN WITH MECHANISMS.
in the header file i have specified max ratio as
first with PARAM,MAXRATIO,1.0E+15
and then with PARAM,MAXRATIO,1.0E+25
but in both cases I did not get the same error.
kindly help....
best regards
kammieo
kindly help....
best regards
kammieo
