Hi, We have used superbolts for our C&E marine boilers currently used on the big deck Amphibs (LHA/LHD only on two ships). The waterdrum has a large dia. enclosure plate that is used to remove the Desuperheater for maintenance. The process to remove and install the door normally takes two shift and a torque multiplier (a real pain in the ass). The use of superbolts reduced this to just several hours, this saved maintenace dollars and decreased down time. There is a set prcedure to use when you plan to remove the bolt. The manufacturer recommends that a penitrating oil be srpayed on the fastener while still hot/warm, this will prevent damage to the small jack bolts when removed. Additionaly they recommend an anti-seize compound suitable for very high loads be used when installing. I can tell you first hand, if you do not keep the superbolts clean and dry (rust free) you will end up cutting them off.
