My employer wants to support a catwalk end with a caged ladder.
On past projects requiring ladders for maintenance access, I have always independently supported catwalks/platforms and attached the ladder to the catwalk such that the ladder itself is not supporting the catwalk or platform.
In this particular case the catwalk is merely a sheet of 1/4" plate with sides bent up as a toe plate. The ladder end has a channel welded under the catwalk edge which the ladder is bolted to. The other end of the catwalk is welded to a conveyor that is pretty rigid, and well supported and bracted.
Assuming you can justifiably say the catwalk/platform has no stability issues, does anyone have any opinions on this approach? Any code restrictions to doing this?
