Ladder Framing for Roof Outriggers 5
reverbz
79
Hey Guys,
I'm trying to frame some outriggers in a wood residential building. See below for what I've initially drawn trying to use a ladder framing approach. the light blue are typ. TJI's. The red are beams and the green are where I can locate posts. There are openings below these beams so there's no wall or posts that can be added. I think the main issue I'm running into is framing the corners of the outriggers. I end up with 2 cantilevered beams and I'm trying to think how we can get around that. Do you guys think my drawing looks reasonable? Should I just have them do steel beams instead even though this is residential? Do you have any ideas on the corners?
There are so many colored lines on your drawing that I don't really know what's going on. But I borrowed your drawing and added an angled blue line. I could cantilever over the corner of the building and pick load from the fascia boards. You'd have some connections to figure out, and you'd need structural sub-fascia. But it should work.
@rwpe thanks for the response and idea. just confirming you were using that to support the rim beams correct?
If I understand correctly that your only vertical supports are the green squares, good luck! This architect is a menace. How do you plan to have any lateral resistance?
Not sure there's any hope for the bottom left corner without this being a diving board.
