Using a cv joint and a universal joint on the same shaft
Mikes1098
8
Does anyone know of any issues making a half shaft with a inner cv joint (which allows the shaft to change length) and a universal joint in the outer position (instead of the outer cv joint)?
I have space limitations where I can't seem to fit the outer cv joint...
Mike
I never understood why they would use a needle bearing for a u joint.
I would think a plain oil lite bearing would work just fine.
The same for roller rockers with needle bearings making a quarter turn each time. Makes me go hmmmm...
I don't know anything but the people that do.
You'd see an even worse problem with false brinelling if you used a plain bearing - all the oil would get squeezed out from under the contact patch and would never get back in.
Cheers
Greg Locock
SIG:please see FAQ731-376 for tips on how to make the best use of Eng-Tips.
Plain bearings need continuous rotation to build up a dynamic oil film. That doesn't happen in a U-Joint.
Plain bearings have a much higher friction coefficient than needle bearings. They would actually run hot in an automotive application.
TOP
CSWP
BSSE
"Node news is good news."
