borobam182
- Mar 3, 2015
- 50
Hello!
First of all – let me say that this is a great forum for pipeline and piping issues. I visit this forum on a daily basis to read about different topics and issues that other engineers have to try and learn more. The discussion and advice is always very informative and helpful.
I now have an issue of my own that I would like some help with. I’ve had a look through the relevant design codes and around this forum and I’m unable to find any information to help me.
I am designing a high pressure anti ice pipework system for an air intake filter house. The design code is ASME B31.3, design temperature is 410 oC, design pressure is 16 bara, pipe material is A312 Gr TP316L and pipe size is 3”.
I need to provide end caps for the 3” riser pipes. I have specified an ASME B16.9 end cap in A403 Gr WP316L material. My understanding was that you would need to use a ‘dished end' end cap to distribute the stresses correctly and also to allow for the full penetration butt weld.
However, our manufacturing team have proposed an alternative and I’m having difficulty to find the relevant clauses in the code to rule out their approach.
They would like to weld on a square flat plate over the ‘hole’ in the pipe instead of use an ASME B16.9 end cap. They will prep the end of the pipe and leave a weld gap between the end of the pipe and the plate to provide some penetration, but I don’t feel comfortable using a flat plate when I would usually specify a ‘dished end’ end cap. A pressure vessel had domed ends - and in my opinion, a piping system is no different. A flat plate would be subject to large bending stresses due to the internal pressure and a 'dished end' end cap can manage these stresses better due to its shape and construction.
Do you agree that the flat plate is not a safe and recognised approach?
Any advice would be very welcome.
Thank you in advance.
Craig.
Craig.
