I'm planning to create a device inside a levitating globe like below:
this device would be able to rotate the globe through some force from the inside. I'm trying to think of the best method to construct a mechanism that can do this.
What makes this mechanical problem difficult is that I want someway of not only rotating the globe how I want, but to also keep it fixed once i find the right place. For now to keep things easier, assume the globe can only spin on one axis. In the future, it would be nice if the globe can tilt up and down.
There is a lot of physics involved and the only vague idea that I can come up with is to have a servo motor on the inside with a lever attached to the insides of the globe. So since its spinning only on one axis, the lever would be parallel to the ground.
Is this the most effective method however? Do you guys have any criticism or anything to add?
