DaveRosser
I have an application in which I would like my VFD to drive a load (a carriage on linear rails) for a set speed and a set distance. At this point I want the VFD to merely ASSIST in moving the carriage, which will now be pushed physically by another machine as well.
The carriage is connected by gear belt to a 1000:1 constant torque motor controlled by a Siemens Micromaster 440 drive with encoder feedback from the motor.
We are currently doing this with a Servo drive system, which of course is much more expensive...and therefore is desirable to replace.
If anyone has experience with such an application your help would be greatly appreciated.
Thank you.
Thank you.
