borobam182
- Mar 3, 2015
- 50
Hi everyone.
I'd just like a sanity check if you don't mind.....
I'd specified standard ASME hardware for a 316L flange (A193 Gr B8 class 2 bolts and A194 Gr 8A nuts).
Our purchasing team has asked the question regarding using A2 hardware.
My immediate response was no, for 2 reasons......
As per ASME B16.5, A2 hardware isn't listed as an applicable bolting material in table 1B. You could perform the calculations to prove its mechanical strength as per section 309 in B31.3, but, even if it passes, when using a 316L flange, the hardware should be A4 shouldn't it?
I don't know whether I should stick by my original statement and insist on A193 Gr B8 class 2 bolts and A194 Gr 8A nuts (which makes my life easier but maybe not theirs), or run the tests on A4 hardware......
Any thoughts, experiences or options would be welcomed.
Thank you in advance.
Craig
Craig
