claforet
- Apr 8, 2010
- 54
I'm trying to create a macro (in NX5) to export a step file from a part file. When I manually export the step file, the current path and filename is automatically put in the export dialogue, but when I run a recorded macro, it inserts the path and filename of the file I wrote the macro with. Does anyone know if there is a "current_path" and/or "current_filename" type tag that I can use replace the string that gets recorded in the macro. I tried the "User Input on Dialog Boxes" option, but for some reason, it doesn't work when I open the save dialogue box in the export window.
