I'm working on tool that incorporates a machining slide that is positioned by a hydraulic cylinder. This hydraulic cylinder will be actuated by an identical hydraulic cylinder driven by a crankshaft ~20 feet away. If the master cylinder being run by the crankshaft compresses 1" per revolution, then the slave cylinder will cause the slide to move 1". There will be a return spring on the machining slide to ensure that the column of fluid always remains compressed. Therefore the system converts the rotary motion of the crankshaft to a reciprocating motion at the machining slide. Positioning accuracy is not a huge concern because i can adjust the 'run out' of the crankshaft to provide the desired motion of the tool slide, so it only needs to be close to 1-to-1 motion transfer within a few percent.
How does one go about filling and bleeding this system? Is this method common in industry? Are there any particular issues or risks with this approach?
thanks,
Danny
thanks,
Danny
