Twoballcane
I use the fasteners in ProM and sometimes the model does not want to mesh. I have used it in simple box models, but when I use it to hold brackets to plates and applications like that it does not want to mesh. Any idea what is going on?
Im using the screw feature
Any help or thought would be greatly appretiated.
Tobalcane
"If you avoid failure, you also avoid success."
