Using Grip To Edit Text In NX Drafting 5
lsl49
33
Due to UG not having True Type Font in Drafting, I currently bring AutoCAD artwork files into UG. The text will appear like this in the UG Annotation Editor: <F1>1000-1234<F>. We assign a new font (helios_bold_con) to the text. In order for the system to recognize the new font, you must edit the text and remove the <F1> & <F>.
Can anyone help me write a grip program to strip this from each piece of text on a drawing? There may be 20-100 occurrences on a drawing that needs editing.
Larry Leonard
Senior Designer
Smith-Nephew Orthopaedics
Here is what I have.
It will not compile. I receive error 79 undefined GPA symbol for (L).
ENTITY/L, ents(1000)
NUMBER/ORIG(3),LNS,RSP, cntr, spot
STRING/NTXT(132),RTXT(132)
data/ cntr, 0
inexte/ all
$$ CAPTURE CURRENT SYSTEM SETTINGS $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
E_CLR_0=&ENTCLR
W_LAY_0=&WLAYER
C_SIZ_0=&CSIZE
C_FNT_0=&CFONT
E_SIT_0=&ENSITE
T_JUS_0=&TXJUST
MASK/25 $$DRAFTING OBJECTS
L1:
spot = -1
L = nexte/ ifend, Z99:
if/ L == &nulent, jump/ z99:
ORIG(1..3)=&ORIGIN(L)
$$ COPY CURRENT TEXT STRING SETTINGS $$$$$$$$$$$$$$$$$$$
E_CLR=&ENTCLR(L)
W_LAY=&WLAYER(L)
C_SIZ=&CSIZE(L)
C_FNT=&CFONT(L)
E_SIT=&ENSITE(L)
T_JUS=&TXJUST(L)
$$ RETRIEVE TEXT OF OBJECT
NTXT=&DMTEXT(L)
spot = FNDSTR(NTXT,'<F1>',1)
ifthen/ spot >= 1
cntr = cntr + 1
ents(cntr) = L
$$ REPLACE TEXT IN NOTE
RTXT=REPSTR(NTXT,'<F1>','',1)
RTXT=REPSTR(RTXT,'<F>','',1)
$$ CREATE NEW NOTE
$$ SET SYSTEM TO THESE VALUES $$$$$$$$$$$$$$$$$$$$$$$$$$$$
&ENTCLR=e_clr
&WLAYER=wlay
&CSIZE=c_size
&CFONT=c_fnt
&ENSITE=e_sit
&TXJUST=t_jus
$$ SET CFONT TO HELIOS_BOLD_CON $$$$$$$$$$$$$$$$$$$$$$$$$$
SET
C_FNT=&CFONT(4)
NOTE/ORIG(1),ORIG(2),RTXT
$$ DELETE OLD NOTE
$$ DELETE/L $$ we can't delete while cycling
endif
jump/ L1:
Z99:
$$ done cycling, so now delete all the old notes
ifthen/ cntr > 0
delete/ ents(1..cntr)
endif
print/ 'CNTR: ', cntr
$$ RESET SYSTEM TO ORIGINAL SETTINGS $$$$$$$$$$$$$$$$$$$$$
&ENTCLR=e_clr_0
&WLAYER=wlay_0
&CSIZE=c_size_0
&CFONT=c_fnt_0
&ENSITE=e_sit_0
&TXJUST=t_jus_0
HALT
thanks,
lsl49
Can someone tell what is wrong?
lsl49
You are confusing global parameters with entity specific parameters. For example, the Global Parameter Access (GPA) &ENTCLR sets the current modeling color only. So if the current color is green and you set it to blue, all entities you create after that will be blue. To use &ENTCLR(L) is an error because it is the wrong command to query or set an individual entity's color (use the Entity Data Access Symbol (EDA) &COLOR(L) to do that). Welcome to the wonderful world of grip programming. You probably now see why its use is no longer greatly encouraged.
Sort out the GPA's and the EDA's and you are well on your way to a working program (it also doesn't like the SET command sitting by itself on line 61). To change the font, look up the ASGNFT command.
It can be useful to have the capture/restore system settings (i.e. GPA's) as sub-routines that you call at the start and end of your program.
I use an _GPA_SAVE.GRS ...
Proc/ Gpavlu
Number/ Gpavlu(43)
Gpavlu(1) = &Apsite
Gpavlu(2) = &Aunit
Gpavlu(3) = &Cfont
Gpavlu(4) = &Cnmode
Gpavlu(5) = &Csize
return
and an _GPA_REST.GRS ...
Proc/ Gpavlu
Number/ Gpavlu(43)
&Apsite = Gpavlu(1)
&Aunit = Gpavlu(2)
&Cfont = Gpavlu(3)
&Cnmode = Gpavlu(4)
&Csize = Gpavlu(5)
return
Paul Phillips
Specialty Engineered Automation
Using the _GPA_SAVE & _GPA_REST & using ASGNFT to assign the font as suggested in a above post:
It reported an error "subscript a non-array variable" on the line 19 (calling out the helios_bold_con font) and program failed compilation.
I received 2 linking errors when I tried to link.
In _GPA_SAVE called from test_program. Wrong number of argumnets _GPA_SAVE
In _GPA_REST called from test_program. Wrong number of
arguments _GPA_REST
Here are the sub-routines:
$****************_GPA_SAVE.GRS****************
Proc/ Gpavlu
Number/ Gpavlu(43)
Gpavlu(1) = &Apsite
Gpavlu(2) = &Aunit
Gpavlu(3) = &Cfont
Gpavlu(4) = &Cnmode
Gpavlu(5) = &Csize
return
$***********_GPA_REST.GRS****************
Proc/ Gpavlu
Number/ Gpavlu(43)
&Apsite = Gpavlu(1)
&Aunit = Gpavlu(2)
&Cfont = Gpavlu(3)
&Cnmode = Gpavlu(4)
&Csize = Gpavlu(5)
return
Here is the current program:
data/ cntr, 0
inexte/ all
$$ Call Subroutine
CALL/'_GPA_SAVE'
ASGNFT/Gpavlu(3),4,IFERR,L1:
L1:
spot = -1
NTXT=&DMTEXT(L)
ifthen/ spot >= 1
cntr = cntr + 1
ents(cntr) = L
$$ CREATE NEW NOTE
$$ DELETE OLD NOTE
endif
jump/ L1:
Z99:
ifthen/ cntr > 0
endif
$$ Call Subroutine
CALL/'_GPA_REST'
HALT
I'm not sure if this is the way I want to go but I thought it might be good experience.
thanks,
lsl49
You'll need to declare this in your main program ...
Number/ Gpavlu(43)
in your case, you can change the 43 to 5, including the sub-routines. My version controls 43 GPA's.
Paul Phillips
Change
Code:
To
Code:
ASGNFT/'helios_bold_con',4,IFERR,L1:
The '4' in the above command means that any note using font number 4 will now be changed to helios bold con, is that your intention? If you just want to be sure that helios bold con is available, use the following:
Code:
  ASGNFT/'helios_bold_con',0,IFERR,L1:
  FNUM=&FNTNUM('helios_bold_con')
Passing a '0' into the ASGNFT command just makes sure that the font is in your font table. The &FNTNUM command will return what number it is in your font table. Now you can use the font number (saved as FNUM) to change a note's font selectively.
Thanks Cowski for the info on "ASGNFT".
Paul, I am still getting "Wrong Number of Arguments" on the sub-routines.
Proc/ Gpavlu
Number/ Gpavlu(5)
Gpavlu(1) = &Apsite
Gpavlu(2) = &Aunit
Gpavlu(3) = &Cfont
Gpavlu(4) = &Cnmode
Gpavlu(5) = &Csize
return
Proc/ Gpavlu
Number/ Gpavlu(5)
&Apsite = Gpavlu(1)
&Aunit = Gpavlu(2)
&Cfont = Gpavlu(3)
&Cnmode = Gpavlu(4)
&Csize = Gpavlu(5)
return
$*********** MAIN PROGRAM *************
NUMBER/ ORIG(3), LNS, RSP, cntr, spot
STRING/ NTXT(132), RTXT(132)
data/ cntr, 0
inexte/ all
$$ Call Subroutine
CALL/'_GPA_SAVE'
$$ ****** SET CFONT TO HELIOS_BOLD_CON *******
L1:
spot = -1
NTXT=&DMTEXT(L)
ifthen/ spot >= 1
cntr = cntr + 1
ents(cntr) = L
$$ CREATE NEW NOTE
$$ DELETE OLD NOTE
endif
jump/ L1:
Z99:
ifthen/ cntr > 0
endif
$$ Call Subroutine
CALL/'_GPA_REST'
HALT
What am I'm doing wrong?
lsl49
Change your "Number/" declaration to be ...
NUMBER/ ORIG(3), LNS, RSP, cntr, spot, Gpavlu(5)
Then for your two "Call/" statements, they need to be written as ...
CALL/'_GPA_SAVE', Gpavlu
CALL/'_GPA_REST', Gpavlu
Are the sub-routines compiling ?
Paul Phillips
Everything compiles and links now,
thanks,
lsl49
This has been very helpful but this current program does not do exactly what I need. Reference 20 Oct 06 11:47 post.
I just have to keep plugging away at it.
thanks
lsl49
I have been able to edit out the <F1>, <F> and the characters 2122.
I am having a hard time editing multiple lines of text.
Any suggestions?
lsl49
To edit multiple line notes you will have to loop through the note entity one line at a time. Below is a code snippet I use to determine the number of lines in a note. One pitfall is it does not report blank lines; so if you have a 3 line note - 2 lines of text separated by a blank line - the code will return '2' as the number of lines of text. This is not a problem for me since the notes this routine works with will not have blank lines, but it is something you may need to modify for your needs.
Code:
ENTITY/L
STRING/NTXT(132,132)
NUMBER/LNS,J
  LNS=0
  NTXT=&DMTEXT(L)
  DO/NMLNS:,J,1,132
    IFTHEN/LENF(NTXT(J))>0
      LNS=LNS+1
    ENDIF
  NMLNS:
