Using Inverter with exsiting slip-ring motor for overhead crane 2
Banphot
3
Hello:
In our steel making plant factory, there is an electric overhead crane with 120 ton hoist driven by 220KW slip-ring motor. The motor is started using 4 steps of rotor resistors, and speed is controlled via SCR circuit.
We would like to install vfd inverter to control speed instead of existing SCR, and utilize the existing slip-ring motor by short rotor circuit at its slip-ring. Could anybody suggest the disadvantage or risk of doing this? Is there any experience of doing this with heavy steel mill crane application?
Thanks in advance.
Banphot
I agree, Roy. You highlighted quite a few crucial things that seldom are discussed. Real useful.
I would never use a TTL output in a VFD environment. The rule is to use 12, 15 or 24 V signals. Filtered inputs and/or differential signalling (A and /A plus B and /B).
Gunnar Englund
Skogs,
I guess TTL was the wrong term to use, what I meant was signal driven in both directions to give a nice square wave.
Roy
