Using Length as a Curve constraint
Recon1775
Aerospace
Jul 24, 2002
137
Does anyone know of a way to constrain a curve by using a length? So say you have a spline between two points and you need the curve to be a specific length... Is there a way to define that length and force the curve to be that long?
Mathematical Operators used in Pro/E Relations - Try a datum curve from equations.
Heckler [americanflag]
Sr. Mechanical Engineer
o
_`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
In sketch mode, select all the elements in your curve. Pick edit/convert to/perimeter. You will be prompted to selected a dimension that the system can vary to achieve the perimeter. A perimeter dimension is created and the selected dimension is changed to varying.
