Using Peng Robinson EOS
valves4life
Industrial
Hi Everyone, I am very grateful for any answers here, as this is something I've been struggling with for a VERY long time. I've tried over and over to find a solution on my own without any avail.
I'm currently trying to get a calculated bulk modulus of substances in order to do a speed of sound calculation.
I've tried using Peng Robinson, but I'm running into an issue. I have MathCad and attempt to solve for V, but am having issues there as well, not finding a solution, probably due to my erroneous MathCad skills. I have Pc, Tc, and w (accentric factor), as well as input pressure and temp. In theory, I should be able to run this calculation and get a volume output, and then just calculate another point, and then I'd solve in the bulk modulus equation with those values?
I'm bashing my head against the keyboard here trying to find a solution and am not finding one. Keep in mind any iterative calculations will be difficult since I'm trying to write a quick javascript file to output this for me, so doing a "guess and check" is not a good option for me. As I said I've been struggling for a long time and in the past I've just ignored any effects of pressure on liquids, but in the last few weeks I've decided to solve this once and for all...
I'm sorry to ask this, but I've ordered books, scoured everything I can find on the internet for what feels like weeks now (it's been at least 2).
Can someone please help??
My experience with cubic equation of state (PR or other EOS) is to write them in terms of Z and solve them using Newton Raphson's method or Halley's method for a faster convergence.
2 equations : EOS and PV=ZRT . Let you substitute V = ZRT/P in the EOS
solve F(Z) =0 ; Zn+1=Zn -F(Z)/F'(Z) with initial guess : Z=1 , Z gas being the bigger root.
It works fine .
Pierre
Hi valves4life,
with proposed procedures you solve molar volume (liquid and vapor phase) *NOT* the bulk modulus which is a derivative
bulk modulus = -V dP/dV
in the same way, if you wish to calculate the speed of sound you need additional derivatives and, for two phase conditions, the solutions is not easy
for MathCad, Excel or open source alternatives as LibreOffice, OpenOffice etc. you can consider to link a thermodynamic library as for example Prode Properties,
with Prode you can obtain all the desired properties (including bulk modulus) plus derivatives directly in MathCad or Excel or ...
