I was asked to review a dwg that uses runout to control a threaded feature.
This is not something I've ever seen before and can't find any use cases where runout is the proper control to use. Is there a case where you'd want to use runout on a threaded feature? If not, what's the argument against it? I would assume you want to control pitch diameter and runout would only control major diameter? How would you inspect this callout?
Thanks.
Thanks.
