I am working with pre and post-dredge data, and need to run calculations between the two surfaces. This project is using a 3:1 slope at the dredge boundaries, and I was wondering if Terramodel can work with specs like this? In the Earthwork Settings, I do not see anything regarding slopes, etc. Maybe this is elsewhere?
For calculations I also use Surfer, but it does not allow the use of slopes and only refers to 'box cut' between surfaces. If Terramodel is not capable of using slopes, are there any recommended programs (besides Civil 3D) out there?
Thanks for your time. Much appreciated.
DP
DP
