Using the Join feature with Configurations
Badierv
Military
Dec 14, 2010
6
Hi all,
I've been searching for a while, but can't find a way to change the configuration of one of two parts that have been joined together.
Thanks in advance.
Same as in a regular assy ... select the part, click the properties icon, and select the config.
What is happening when you try?
That's a Combine ... which is used in a part!
The thread title stated Join ... which is used in an assy.
Apologies, it is a combine. I am not an expert with Solidworks by any stretch of the imagination and it was the first time I had used the features.
That said, any insights on how I change the configuration of a part in a Combine? Or do I have to recombine them?
What version of SW are you running?
I'm running SW2011-SP3 and the inserted parts remain above the Combine feature, and the List External Refs list the configs.
Can you list the exact steps you did to arrive at the Combined feature?
 http://files.engineering.com/getfile.aspx?folder=45b87057-9150-41aa-8bd0-6a613d3db4f9&file=Combine-ExternalRefs.png
I'm running SW2010-SP4.
This was a while ago, so hopefully I'm not forgetting a step.
Opened the edi top test slant.SLDPRT file
Went to Insert->Part
Selected transducer.SLDPRT
Positioned the transducer housing where I wanted it on the case
Clicked Combine, Add then ok and the two parts merged.
The configuration option should be as CBL stated... in list external references. It was there as far back as I can remember... ~2003 at least.
-Dustin
Professional Engineer
Pretty good with SolidWorks
Thanks CBL, that worked a lot better. Now I have access to the configuration options again. Thank you so much for your help!
