If you right click on a tool and go to object then custumize and go to customizable items in the drop down. Then you can add coolant through to your tool parameters as a check box. I am trying to add a custom cammand that looks at this box and if it is checked then add through coolant. If not checked then do nothing.
Im not sure how to have the post look directly at this one check box within a custom command?
If anyone knows of a way to accomplish this i would really appreciate it!
Thanks.
Thanks.
