When using Section VIII-2 Part 5 elastic-plastic analysis (with a load factor of b=3.5 for protection against plastic collapse; and 1.7 for protection against local failure) on a vessel (or component of a vessel) that is designed per VIII-1 (and U-2(g)), is it a generally accepted engineering practices to apply Part 5 in full (including Paragraph 5.5: protection against failure from cyclic loading). Or is the load factor against plastic collapse (b=3.5) high enough to eliminate the risk of cyclic failure modes?
