amar122amar
Chemical
Three sensors are mounted on a vessel (V) at elevation of 6000 mm (sensor A), 6600 mm (sensor B) and 7200 mm (sensor C). These three level switches generate a trip signal (2oo3 voting logic) to stop flow from upstream system to vessel (v).
Can we use sensor A to control level in vessel (V)? On actuation (healthy condition) of sensor A, valve at the bottom of vessel (v) will open and on reset of sensor A, valve at bottom of vessel (v) will close.
