V5 Drawing custom sheet size 3
alexlaurenceau
Automotive
Nov 12, 2003
20
Hello everyone,
I would like to create a sheet of 36inx100in for our drawings. Does anybody know how to define custom sheet size in the drafting workbench? I tried running in admin mode and access the XML standards but I don't seem to find any parameter for the sheet size.
Thanks in advance.
Alex Laurenceau
Hi Alex,
One way is to use a macro..and..
..if you would try this link:
somewhere deep there you will find references to
"CatPaperSize" and
"CatPaperUser"
Good Luck,
Sincerely,
Mircea
easy way to create user specific size for drawing is:
File/Page Setup
In Format field type User36x100 and press TAB-key
then Width and Height fields will activate.
Regards TPale
Hi Alex Laurenceau,we can set sheet height and width as Tpale said manually,and we can set itz format by macro also as Alex said:
macro is like this
Set DrawingDocument1 = CATIA.ActiveDocument
Set DrawingSheets1 = DrawingDocument1.Sheets
Set DrawingSheet1 = DrawingSheets1.Item("Sheet.1")
DrawingSheet1.PaperSize = CatPaperUser
DrawingSheet1.SetPaperHeight 800mm
DrawingSheet1.SetPaperWidth 1150mm
Hope it works for u
bye
Naveen
Thank you all for your quick response. All your tips where helpful and they worked for me.
Thanks again and have a good day!
Alex Laurenceau
