V5r10 Sheetmetal - Bend radius - Inside / Outside
TRICON
Automotive
May 28, 2002
3
Is it possible in V5r10 Sheetmetal to change where the bend radius is calculated. I want to maintain the outside dimension of an object that I'm designing. I need to use the command " Bend from flat" for some of the bends. After preforming this command and doing a measurement check accross the width of the part, the part is wider than the original sketch. I need to change the calculation from inside bend radius to the outside so that the original width dimension is maintained.
Thanks for any help.
